3 members (Rich'sToys, Nick in Manitou, Bill Hanlon), 88 guests, and 2 robots.
Topics128,062
Posts1,055,854
Members48,428
#900681 12/02/2012 3:05 PM
Boxing the frame on my 39 1/2 ton. You guys mounting the cab solid after boxing the frame? Or are you leaving a small window to install the spring on the mount just in front of the gas tank?
lol no one wants to let me in on how they mounted their cab after boxing the frame?
I had a 1929 1.5 ton Chevy I had to box the frame on. My plan was to put 3/8" plate inside the frame at each mounting hole to drill and tap later. I sold it before I finished it.
http://www.bunchobikes.com/my1929chevy.htm
thanks mn. I was just going to weld a nut at each spot, but i think i like your idea better.
i drill and taped a 1"x1"3/8 plate then welded it to the inside of my frame at allthe mounting points
My plate served a double purpose. It also spaced out the box plate.
