| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 38 New Guy | | New Guy Joined: Oct 2012 Posts: 38 | Boxing the frame on my 39 1/2 ton. You guys mounting the cab solid after boxing the frame? Or are you leaving a small window to install the spring on the mount just in front of the gas tank? | | | | | Joined: Oct 2012 Posts: 38 New Guy | | New Guy Joined: Oct 2012 Posts: 38 | lol no one wants to let me in on how they mounted their cab after boxing the frame? | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | I had a 1929 1.5 ton Chevy I had to box the frame on. My plan was to put 3/8" plate inside the frame at each mounting hole to drill and tap later. I sold it before I finished it. http://www.bunchobikes.com/my1929chevy.htm | | | | | Joined: Oct 2012 Posts: 38 New Guy | | New Guy Joined: Oct 2012 Posts: 38 | thanks mn. I was just going to weld a nut at each spot, but i think i like your idea better. | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | i drill and taped a 1"x1"3/8 plate then welded it to the inside of my frame at allthe mounting points | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | My plate served a double purpose. It also spaced out the box plate. | | |
