Brrrr
place holder
9 members (Peggy M, dt235sd, 50Chevy3100, klhansen, Hush, Charles in CA, Nick in Manitou, 41 chev, 1 invisible), 344 guests, and 4 robots.
Topics128,270
Posts1,058,408
Members48,485
#901946 12/07/2012 5:48 PM
Ok gentleman I have a 38 GMC, it has been changed over to 12 volt neg ground and I am running an alternator. Right now I am using the original gauges but will be replacing with different/new gauges (77 Datsun 280Z gauges) I know how to by past the amp gauge but I am having a massive brain fart on how to hook up the volt gauge. Can I just hook the volt gauge up to to switched side of my ignition switch it is the original switch (just on and off no start) or is there some other place that is better. I have a rebel wiring harness in my truck and I did all the wiring ?????
1938 Gmc 1/2 ton
just use a "t" splice off of the gauge power wire. i've used many rebel kits, and works for me.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
so I could add a wire for the volt gauge right where I splice the wires back together from the amp gauge.
1938 Gmc 1/2 ton
That would work.
yup
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
told ya I was having a brain fart
1938 Gmc 1/2 ton
