1 members (1 invisible),
78
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | Torque tube 1948 1/2 ton.Pinion lock nut is broke at lock clip so i can not lock it into the slot.Any ideas were to get one, is this a necessity.Tack with a weld?Thanks | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you put a thin shim/washer under nut it will tighten and stop in a new position. You can then lock it in a new spot. There are a few new ones on eBay
See the USA in your vintage Chevrolet! My Blog | | |
