0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#901620 12/06/2012 12:24 PM
Torque tube 1948 1/2 ton.Pinion lock nut is broke at lock clip so i can not lock it into the slot.Any ideas were to get one, is this a necessity.Tack with a weld?Thanks
If you put a thin shim/washer under nut it will tighten and stop in a new position. You can then lock it in a new spot.
There are a few new ones on eBay
My Blog
