| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Hi All, After a few tries, the lever from the foot pedal is not quite hitting the starter switch anymore. It will work with a 1/4 inch spacer between lever and switch.
Can the switch travel be adjusted back outwards somehow?
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Is it possible that the starter lever that contacts the switch is in backwards? 1/4" seems like a lot unless something is interfering with the linkage when you push down. With my pedal in the up position I have approx 1/2" clearance between the lever and the switch button so your pedal should move at least that far to engage. Is this a new starter? If you could post a picture that may help. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1218.htm
Ed
| | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Thanks, everything seems as original, it is just that the button switch is squashed down shorter than the one in the manual illustration. So the lever doesnt travel far enough to push it in enough.
An old post said to jbweld a nickle to the top of the button switch, I was just wondering if there is another way to clean or adjust it, or if it is time for a new switch.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | have you removed and inspected the switch box? might just be the return spring in it is broken or worn out
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sounds like it is time for a new switch, or the need for a new contact-point on the starter.
I have gotten life out of worn down switch by taking a 2-inch length of old garden hose and slitting it so that it can be opened. I then slid the hose over the button. This worked fine for several years.
However, replacing the old button is not a very difficult or expensive undertaking.
Sometimes its not the switch that is worn-down; it is the copper "button" contact-point on the starter body. Replacing that is a little more complicated a job.
