1 members (Otto Skorzeny), 81 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#901510 12/05/2012 9:41 PM
In the process of the hei conversion on my 261. Not sure if the hei has more or less mechanical advance. I was thinking about setting " total advance" but not sure what these motors like. Or should i set it like the stock dist.
52' Chevy 6400 2 ton
I like to set it for best vacuum. It is more advanced than the stock setting.
Its a trial and error thing. Compression can make the engine ping with to much timing, so depending on how much mechanical advance yours has, you will have to adjust according. Each HEI is a little different when it comes to advancing, some just keep going, some come in quick, some very slow, there is a endless combination of springs and weights to choose from.
Total timing can vary from 32 to 36 degrees, again it depends on how your engine responds. Its pretty easy to change, so try a few different settings and see how it runs. Full throttle short blasts will tell you a lot, also long hills where you can work the engine are helpfull. Ideal timing is where the engine has very slight ping when working up a hill at medium throttle, the ping should go away if you step down enough to open the power circuit in the carb and drop a little vacuum. New cars run right on this edge all the time thanks to the computers and constant adjusting.
Joe
You don't mention which HEI you have, is it a Pertronix or factory. IF factory HEI they all had progressively less mechanical and vac advance through the years. Which accounts for the Joe H observation that they all very.
Larry
I don't own a vehicle that isn't old enough to drink.
I have spun a lot of then on dad's machine and have yet to find two the same!
Joe
