4 members (66flea, 1955 1 Series, UtahYork, Deegs53), 311 guests, and 4 robots.
Topics128,156
Posts1,057,018
Members48,460
I have a 3 speed torque tube trany, I was hoping to ho up the column shift but i need a new column, tll then i need a floor shift. will a 1956 Corvette 3 speed shifter fit the torque tube 3 speed?
also , will it fir a sm 318/319?
thanks for any halp guys!
I don't know about all that, but there were floor shifters available years ago, Mr. gasket, and I think Hurst. I'm not sure if they make them any more, but it would give you something to think about.
Hurst makes a 3 speed floor shift conversion, it would take some adaption to use on a torque tube trans though.
My Blog
ODSS President
ODSS President
I converted to the floor shift for my '62 Muncie 3sp+od, I believe this model is called 319. I did not want to cut up my floor so, using the floor pan as a template I traced out a new 'pan' from plywood. Measured twice cut a couple times.
The challenging part is that when you have the floor pan out and you are seated in the driver's position you realize that the shifter will be right on your right thigh. I fabricated my own bracket and then welded an 'over-up' to place the shifter away from my leg and closer to the middle of the floor. Has worked beautifully for my daily driver '49 the last 12 years.
If you go this way I'll post pictures if you pm me.
Regards,
Cosmo
~ Cosmo
1949 Chevy Half Ton
Try this: http://www.nationalchevyassoc.com/documents/NCA_125_lowres.pdf
They also have lots of used parts for sale. Including cluster mechanisms, transmissions, etc...
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
