8 members (68ironhead, lumbersawyer, 48jim1ton, Woodcmiami, 3B, J Lucas, Ponchogl, 1 invisible), 97 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#90094 04/28/2005 4:54 AM
Junior Member
Junior Member
Why would my genartor light stay on ? is the genartor out or osmthin its for a 62 chevey c-10 any one help plz ?
life rolls on a?
#90095 04/28/2005 9:40 PM
Brushes shot?
Buzz'n Half Dozen
#90096 04/28/2005 9:56 PM
Riding in the Passing Lane
Remove the field wire from the regulator & ground it. If it charges then the regulator is bad. If not the gen. is bad or something wrong in the circuit. Its best to check it with a voltmeter. The voltage will increase from the basic 12 volts if it is charging. Do not run it very long or fast with the field grounded.
1972 Chevy c10 Cheyenne Super
#90097 04/30/2005 6:56 AM
Don't wait to long to fix the problem. Your battery will run out of juice before to long. Cecil........
#90098 05/01/2005 2:45 PM
real loose belt
Redryder pix
My Hotrod
