0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
How do all, I need a new "rubber" diaphragm for my 2 speed rear end. It's probably original. And is cracked and leaking. I found a new seal for the piston. Which used to let 90 weight be sucked into my motor.Scared the crap out of me cuz I have a brand spankin new 235-250 now that was blowing white smoke at start up. Figured it out tho. But need the new rubber and don't know who might have?
1949 chevy 6400
2 ton
2 speed rear end
I looked everywhere for mine and the only thing I could find was the complete unit for like $300. So I got a inner tube for a lawnmower and cut a circle out of the outer part that touches the tread so I had a round dome shaped piece and use that it works great.
That's very cool. And I am that type of guy as well. Good idea. Cuz I was thinking about what I was going to use that had some cyrvature to it. Thnx Bud!
The diaphragm part number is 3847058. This part was used on early 70's trucks and thus can be still obtained at GMC parts departments. You may have to ask them to use their obsolete parts locater computer. I was able to get a brand new one from a GMC truck center in Phoenix.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Crusing in the Passing Lane
Inner tube mat'l is not neoprene, might not last very long in that application.
I used a double-layer of "boot"material(22"inner-tube liner),for my application. I re-built one back in the '80's,and it lasted until the truck,('60 Apache 60),got so badly rusted,that when you applied the brakes,the cab would shift and the gas pedal would jam to the floor! Wasn't long b-4 that poor tired old 283 threw a rod at a stop-light! Wasn't neoprene,but it lasted 10 years with about a million splits in that amount of time. I hauled a lot of building material,and roof tear-off's with that old girl.
Mo' Tater
I'm going to toss this out-- I've not tried it, but it's a thought.
How about the diaphragm from an air brake chamber. They come in a lot of different sizes. Maybe one of them is the correct size?
I know they are tough- I've cut a couple up to make rubber seals for something else.
Try obsolete chevy 1-800-2488785 I'm pretty sure they have them. I thought I needed one but disassembled mine, pulled it with a vise grip a few times, rubber looked good, reassembled and it's worked fine.
