| | | Forums66 Topics128,164 Posts1,057,081 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | so my buddy ed has a 63 chevy with a really mild 350. i think it orig. had a short tail saginaw. he wants to put in a sm319.
we know he needs to shorten the shaft and mabey deal with flywheel/clutch. does he need a new yoke?
what else is he gonna have to do
| | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | A SM 319 will bolt right in, but as for the shift linkage, you will just have to try it and make it work. The yoke will probably fit and shorting the drive shaft is no big deal. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Use the(4 bolt)side cover from the original trans if the one on the OD is indexed differently. It's probably a good time to replace the clutch. Install the electrical components, kick down switch & bracket, pull cable & drive it. Best kept secret on how to make these old trucks more efficient. Fred
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | And you really only need the cable and a toggle switch.
See the USA in your vintage Chevrolet! My Blog | | |
