1 members (Steveoreno), 111 guests, and 2 robots.
Topics128,195
Posts1,057,375
Members48,469
#90032 08/21/2004 2:35 AM
A quick question please...
I have a new firewall pad for my 64, and also a new aftermarket fuse block.
Do I mount the fuse block on top of the pad or mount the block first and then cut the pad?
Its been a long time since I tore all that stuff out! wink
Thanks!
Sittin' Pretty in My Old Kentucky Home.
http://www.picturetrail.com/barneysbowtie
#90033 08/22/2004 1:44 AM
Junior Member
Junior Member
On my 59 I installed the pad and all I had to do was knock out the small rectangle for the mounting tab!
rebuild not replace
#90034 08/22/2004 4:22 AM
I did my 64 just as Bob describes; have fuse box hanging loose, install pad, punch out "holes" for fusebox, remount, done. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#90035 08/22/2004 8:11 PM
Thanks guys...Just doing a checklist for re-assembly and I didnt pull the new pad from the rafters and look at it to see the punch out.
But then again, I'm an idiot. wink
#90036 08/24/2004 4:08 AM
I know someone who's horn did burn out. Its
probably ok as long as you don't stay on it
very long, but if it were me, I'd put in the
resistor for insurance. Just remember to keep
the resistor away from contacting anyting.
They get very hot.
