2 members (Sjm, Wisner955),
95
Mod | | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | I have a 1963 chevy 1/2 ton with the factory 3 speed trani in it.My question is can I put a turbo 350 in it with the low hump floor pan or will I need the high hump pan for clearance? Thanks Longhorn | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | It should fit. But others that know better will chime in soon. But it should go right where the 3 speed went.
May have to move (or make) a rear transmission mount and cross member though.
Depends on if your three speeds bell housing sits on cross member, or if the rear of the three speed sits on a cross member.
Been too long since I looked at a 63. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The T350, T400 & Powerglide, will clear the low transmission hump. You will need to remove the manual transmission cross member and install an automatic transmission crossmember, in the correct tailshaft mounting location.
| | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | You will also need to shorten the driveshaft, change the front yoke to the fine spline that auto transmissions use, install an oil cooler & lines, transmission kick down cable/bracket, and either modify the column shifter or use some aftermarket shifter. Fred
