3 members (NAPCOStormTrpr, Lightholder's Dad, Gdads51), 82 guests, and 2 robots.
Topics128,076
Posts1,056,280
Members48,441
Can anyone point me in the right direction? Looking for a complete kit if one is available. Thanks!
I can't think of a kit specific to that year truck, but there's several universal kits out there, check Summit, Jegs, and Speedway. You might also be able to adapt the bellhousing and clutch slave cylinder from a '60-'62 to work as well.
Just out of curiosity, though, any reason you're wanting a hydraulic clutch?
Bill Burmeister
Thanks! I bought cpp firewall mounted disk brake kit. With the new kit the brake pedal hangs so I'm thinking I won't like one hanging and one on the floor so my thought was to go with a hydraulic kit for ease of making both the clutch and brake pedal hang. Anyone have any other thoughts or options maybe I missed?
Simple- - - -build a bracket to mount a mid-1960's Dodge slave cylinder to operate a regular Chevy throwout fork. Use any aftermarket master cylinder you choose that provides the right bore size ratio between master and slave cylinder to make the pedal effort correct. Or, use the appropriate Dodge clutch master cylinder and adapt a swing pedal assembly to push it.
Then there's also the racing-type inside-the-bellhousing hydraulic throwout assembly if you want to spend waaaaaayyyy too much money.
I dunno if you want to do that. I own a '67 Dodge truck with the aforementioned hydraulic clutch and I hate it. You get no pedal feel. Worst driving stick shift I've ever owned. Planning to convert it to an auto after my '46 Chevy is done.
I had several vehicles with hydraulic clutches and I'm real glad I no longer own them.
