| | | Forums66 Topics128,141 Posts1,056,487 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Can anyone point me in the right direction? Looking for a complete kit if one is available. Thanks! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I can't think of a kit specific to that year truck, but there's several universal kits out there, check Summit, Jegs, and Speedway. You might also be able to adapt the bellhousing and clutch slave cylinder from a '60-'62 to work as well. Just out of curiosity, though, any reason you're wanting a hydraulic clutch?
Bill Burmeister | | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Thanks! I bought cpp firewall mounted disk brake kit. With the new kit the brake pedal hangs so I'm thinking I won't like one hanging and one on the floor so my thought was to go with a hydraulic kit for ease of making both the clutch and brake pedal hang. Anyone have any other thoughts or options maybe I missed? | | | | | Joined: Feb 2004 Posts: 29,820 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,820 | Simple- - - -build a bracket to mount a mid-1960's Dodge slave cylinder to operate a regular Chevy throwout fork. Use any aftermarket master cylinder you choose that provides the right bore size ratio between master and slave cylinder to make the pedal effort correct. Or, use the appropriate Dodge clutch master cylinder and adapt a swing pedal assembly to push it.
Then there's also the racing-type inside-the-bellhousing hydraulic throwout assembly if you want to spend waaaaaayyyy too much money. Jerry
| | | | | Joined: Oct 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 52 | I dunno if you want to do that. I own a '67 Dodge truck with the aforementioned hydraulic clutch and I hate it. You get no pedal feel. Worst driving stick shift I've ever owned. Planning to convert it to an auto after my '46 Chevy is done. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I had several vehicles with hydraulic clutches and I'm real glad I no longer own them. | | |
