| | | Forums66 Topics128,156 Posts1,057,018 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | I have turned it over by hand several times.
New oil in it. Yesterday, with power to distributor bypassed, turned it over using the starter using a jumper wire. sounds beautiful. She hasn't done that in 15 years, but ran perfect when it was parked.
Does anyone see a major issue with using the stater to prime the oil system? I really wasn't looking forward to removing the distributor to turn the pump manually. I figured i would turn the motor over in 10 second intervals for a few mins, making sure the starter doesn't overheat.
1950 Chevy 3600
| | | | | Joined: Feb 2000 Posts: 5,233 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,233 | Pull the valve cover and watch for oil on the rocker shaft. Have a oil pressure gauge hooked up where you can see it, don't trust the dash gauge if its been setting the same amount of time. You can buy oil gauges pretty cheap and " T " them into the system.
I am assuming this is a 235 that uses the copper/brass line to feed the rockers? Those line plug over time, so it may never oil the top end, but a oil gauge will show pressure at the crank. Even when new, the pressure was low compared to a modern engine, so don't expect a lot out of it.
If the battery is good and the starter sounds good, no problem with priming a used engine this way. If you want add a extra quart or two of oil so the crank is setting in it till you know the oil pump is working. At least the mains and rods would be covered in oil.
Joe | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | The problem with doing it this way is you are dragging those rings down a cylinder wall that hasn't been lubricated in 15 yrs. Even though it sounded nice when you cranked it, you had better do a compression check to see if you damaged the rings or walls.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | where does the oil guage attach?
1950 Chevy 3600
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Brad,
You might want to remove all your plugs and squirt some wd40 or something into the sparg plug holes. Then turn the engine over with the starter with the plugs still out to charge the system with oil. It will be much easier on your battery and starter. Don't run the starter for more than 15 seconds or so before you let it "rest" a bit.
She might smoke a little from the oil in the cylinders when you start her.
Kurt | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Brad,
I put a table spoon or so of marvel mystery oil down the spark plug holes in my 235. It had sat for 40 years before I started it. A little oil, as others have already said, sure helps things along.
You might want to also squirt some oil over the rockers and valves, and turn the engine over/ start 'er up with the rocker arm cover off, to verify that there is oil up in the rocker tube.
You can "Tee" the aux pressure gauge right at the block where the factory gauge line come off. This is also where the oil filter is "Tee'd" into the oil pressure. Your FLAPS will have the fitting you need, it should be 1/8" NPT. They should also have a cheap gauge, as fitted on compressors and such, you only need a gauge that goes to 30 pounds. | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Awesome. Yeah i used a turkey baster to put some mavel in the cylinders a while back and let it set for two weeks before turning by hand. with a prybar on the flywheel turns over great.
1950 Chevy 3600
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Nice! The mystery oil makes a great smoke screen. When I first got mine running, the neighbours thought my carport was on fire. It was great. | | |
