3 members (TexasJim50, Peggy M, TexasA&M48Truck), 105 guests, and 6 robots.
Topics128,094
Posts1,056,058
Members48,433
#899427 11/26/2012 4:38 PM
Is there any information / pictures of original pedals used with new updated boosters / master cylinders ?
im in the middle of upgrading my truck from single to dual master cylinder, and keeping my original pedals, im making my own bracket to bolt right to my original mounts ..... [IMG]http://i629.photobucket.com/albums/uu14/kurtdh519/mastercylinderbracket.jpg[/IMG] this will allow me to attach a newer master cylinder to the original pedals, looks like i might need to make a longer pushrod tho.....shouldnt be too hard
can you keep me updated with pics and progress? I purchased the new cylinder / booster for the set up and it says it will mount to the original bracket by drilling holes ,i just don't see it. Thanks for the reply
Most require an adapter bracket like this member used
...jocks site...
Here's a look at the ...bracket...
You may have to relocate a crossmember, I went with a Manual master cylinder for my front disc set.
thanks a lot guys, the booster / master cylinder that i have has that bracket already !!! i have power disk / disk set up. and the new cross member also.
...jocks site...
I like the looks of your master cylinder and pro valve. Can you tell me more about it?
I just bought a front disc brake kit for my '49 and need to upgrade those parts.
Click the link to see my truck.
http://smu.gs/OuBwfv
sure thing, ill take pics when i get it together
