1 members (tesa),
142
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Is there any information / pictures of original pedals used with new updated boosters / master cylinders ? | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | im in the middle of upgrading my truck from single to dual master cylinder, and keeping my original pedals, im making my own bracket to bolt right to my original mounts ..... [IMG] http://i629.photobucket.com/albums/uu14/kurtdh519/mastercylinderbracket.jpg[/IMG] this will allow me to attach a newer master cylinder to the original pedals, looks like i might need to make a longer pushrod tho.....shouldnt be too hard
| | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | can you keep me updated with pics and progress? I purchased the new cylinder / booster for the set up and it says it will mount to the original bracket by drilling holes ,i just don't see it. Thanks for the reply | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Most require an adapter bracket like this member used ...jocks site... Here's a look at the ...bracket... You may have to relocate a crossmember, I went with a Manual master cylinder for my front disc set. | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | thanks a lot guys, the booster / master cylinder that i have has that bracket already !!! i have power disk / disk set up. and the new cross member also. | | | | | Joined: Sep 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 45 | Most require an adapter bracket like this member used ...jocks site... Here's a look at the ...bracket... You may have to relocate a crossmember, I went with a Manual master cylinder for my front disc set. I like the looks of your master cylinder and pro valve. Can you tell me more about it? I just bought a front disc brake kit for my '49 and need to upgrade those parts. Thanks | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | sure thing, ill take pics when i get it together | | |
