1 members (Rnl364), 104 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#899063 11/24/2012 8:17 PM
Has anyone hear of a vented cap on the 1939 chevy p/u? We found one on our truck. It looks like an original manufacturer cap, but never seen such a thing.
3B Offline
Hy Oldschooldude, all of the older master cylinders had vented caps, I'm not really sure when they stopped, somewhere in the 60s I think, hope that helps.
Thanks for the info. The cap on my 46 is not vented, so I was wondering about the 39.
This is the cap I see on most I work on. Cap link Of course if you say it fits Corvette you can ask more for it.
My Blog
That looks like it.
this cap is harder than heck to take off. any tricks or advice?
1937 Chevrolet Carryall http://www.oldmemoriescc.com/images/blvdbombs/images/IMG_6465_JPG.jpg
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
Any tricks?
http://www.knipex.com/index.php?id=...etail&parentID=1368&groupID=1500
Knipex "plier wrench" like an adjustable wrench but it gets tighter and tighter as you pull on it and dosen't harm the part.
Put some anti-seize on it next time
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
thanks for the advice
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
ok thanks for all the advice, the weather has cleared up and i was able to manage to pull out the master, took it over to my buds shop and using the vice the plug came off.
QUESTION: would it be wise to buy the rebuilt (sells for 39.99) or buy a rebuilt master for 49.99 (ebay) the concerned my bud said was that the inside of my master might be damaged due to being old? or unusable?
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
When I took mine off and apart there was rust pits inside, cause by by moisture in system, you can try to hone pits out. From a safety point why chance it, I replaced mine. 57 chev 3800
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
thanks im getting a rebuilt done for $50
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
I rebuilt the one on my 58 2 years ago and have had no problems. The top cap can be removed with a 4 way lug wrench. I found that out 50 years ago with my 1950 3100 work truck on the side of the road with no tools.
thanks
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
