3 members (BC59, rfs56trk, Otto Skorzeny), 158 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
I am trying to find the guy in I think Missouri that does the Hydrovac units. ReMan Incorporated I think, but I can't find the website anymore. I used him before but can't seem to find him again. Any help would be greatly appreciated. Thanks!
1st Gen. Dodge Cummins 4x4 OVRTRQD Buick GNX #276
"If it died... we can fix it" | "If your not outraged, you're not paying attention." | "Do you know a large group of baboons is called a Congress? That explains a lot." ~author unwn
I don't have info on that individual, however I found that Haldex had mine in a remanufactured unit that was very reasonably priced at about $160.00.
http://www.haldex.com/North-America/Applications-Products/Literature/Brake--Suspension-Systems-Literature/Vacuum--Hydraulic/?pdf=%2FDocuments%2Fhbsna%2FVacuum-Hydraulic%2FL00133%2520Vacuum_Hydraulic%2520Catalog%2520Rev.%25207-12.pdf
V
VEW Offline
V Offline
Alretta Trucking and I've heard NAPA also rebuilds them.
~ Victor
1957 3100 - moved on
Precision Rebuilders near St. Louis handles them for many truck repair shops. They have gotten expensive in recent years, I'm sure because of liability issues. We expect to pay anywhere from $350 - $600 per rebuild, depending on the unit. I've never asked, but I assume there's a warranty of some sort included.
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Don't mean to sidetrack your thread, but hydrovac systems are dear to my heart , argh.
I have a 1953 6400 chevy, it does not get driven much so it seems I'm always messin' with the brakes. I bet I pump em 25 times just to get a pedal after its been sitting. It will stop fine but it will not hold a pedal. I can pump it up to a fairly hard pedal but after a few minutes it will go back to the floor. I'm always adding brake fluid, and have no idea wheres it's going? the rascal ( master cylinder) is always dry after sitting for awhile. There are no leaks from the master cylinder or wheel cylinders that I can see....
Also have a 1966 60 series with a hydrovac system, oh joy
..."some gave all, KIA"...
Fixed! ajusted brakes, installed new master cylinder and bled the dickins out of it.
Speaking of hydrovacs.
Has anyone ever changed theirs for a modern master cylinder and a vacume booster in the original location of the m/c? I have a 42 1 1/2 ton. It seems that having a more modern set up would be a good way to go if possible.
