2 members (TUTS 59, Maybellene), 157 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#899532 11/27/2012 1:49 AM
so the exhaust manifold on my 235 has a broken bolt flange.
I have another take/exhaust, can I swap them with out a new gaskit or do i NEED a new one
Socket Breaker
Socket Breaker
It would help if folks knew what year/make/model truck...
-W
I would use a new gasket
its a 53 1/2 ton burb with a 56 235
Thats a very cheap gasket, Why even take the chance of doing it twice.
I agree, use a new gasket, those gaskets wont be reuseable due to all the heat and crush put on them.
You might luck out using the old gaskets, but it is not a good bet.
If you want to try to save some money, go with the old gaskets. It's your time wasted if it they do not seal. Sealer is not normally used or required, but, with old gaskets, you might want to use a high-temperature gasket sealer on both sides of the old gaskets.
Before installing the new assembly, place it on a flat surface to see if the mating surface is flat from end-to-end.
get a new gasket, there are very few situations where I don't use a new gasket, the whole set is $20 at napa. It's worth $20 to me to not have to take it back apart, because it is almost certain you will have to take it back apart. This is definitely one application where I wouldn't even contemplate re-using a gasket.
