0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | There is a grounding strap from my steering column that is not hooked to anything. I know...hook it to something. Looks like it was hooked to valve cover (only thing it will reach)
My question is what is it grounding??
1966 GMC Suburban 305 V6
Thanks | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Horn, won't make it to firewall to ground, I'm not in favor of the valve cover.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | There's nothing wrong with grounding to the valve cover, as long as your engine is well-ground to the frame. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The steering column, is grounded through the rag joint, to the steering gear box, to the frame. There is a ground strap, in the factory rag joint, that jumps through the rubber, from the steering column flange, to the flange that connects to the gear box splined shaft.
Additionally, there are ground straps, in the following areas:
Firewall-to-valve cover - left side Firewall-to-valve cover - right side Inner fender-to-frame - right side Firewall brace-to-frame- right side
