11 members (2-Ton, wvstovebolt, MTD91, Gdads51, Otto Skorzeny, TexasJim50, RaNfLaS, TexasFarmTruck, dt235sd, 2 invisible),
101
Mod | | | Forums66 Topics128,290 Posts1,058,554 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 25 New Guy | | New Guy Joined: May 2005 Posts: 25 | Replaced exhaust manifold gasket last week-cannot get manifold gasket to seal-Several exhaust leaks. Used Felpro gasket. Plan: Remove manifold; Have manifold mating surfaces machined; Clean head; Replace gasket and manifold. QUESTIONS: Type of gasket recommended?; Gasket sealant recommended?; Torque specs for manifold bolts? Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Did you also replace the gasket at the Heat box? Leave everything loose and torque in sequence. I did take my manifold to a machinist Just a dab of sealant to hold in place , but none is necessary. Used felpro gaskets | | | | | Joined: May 2005 Posts: 25 New Guy | | New Guy Joined: May 2005 Posts: 25 | Thanks for the reply. Did not replace heat box gasket..one of the only places it doesn't leak! Will replace HBG before shop work. Have new Felpros.... Thanks for the torque requirements, Jones | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Make sure the intake manifold alignment rings aren't jamming up the fit.
regards, Leon | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Like Leon said, make sure the alignment rings went in straight. If you can not push the manifold up tight to the head with out the help of the bolts STOP. A lot of the time the exhaust manifold warps up at the ends. If this happens the alignment studs on each end keep the manifold out of position for the intake rings to line up. A lot of the times I have to leave out the end alignment studs.
See the USA in your vintage Chevrolet! My Blog | | |
