0 members (), 115 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
#898883 11/24/2012 8:48 AM
I recently replaced the kickdown bracket & cable on my Turbo 350. I now can't get the kickdown hookup rod all the way back in to the trans to bolt down the housing.
Do I have to pull the pan to see if I dislodged something or is there a secret to getting the rod to seat properly? The plunger seems to wotk freely.
Thanks, Mark.
1958 GMC Suburban Carryall
Never accept a drink from a urologist!
The rod should stick out of the transmission about 1" or a little more. The cable housing has a large-diameter section that allows the rod to go into it about another 3/4" or so when the throttle linkage goes to full travel. If the rod is sticking out further, you'll need to drop the pan and see what's going on inside. It's a very simple setup- - - -the ONLY thing the cable does on a 350 is initiate the full-throttle downshift. The modulator controls the shift points.
Thanks Jerry. For some reason I wasn't notified of your reply.
I finally got it in with the top hat seal intact.
