| | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | I recently replaced the kickdown bracket & cable on my Turbo 350. I now can't get the kickdown hookup rod all the way back in to the trans to bolt down the housing.
Do I have to pull the pan to see if I dislodged something or is there a secret to getting the rod to seat properly? The plunger seems to wotk freely.
Thanks, Mark. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | The rod should stick out of the transmission about 1" or a little more. The cable housing has a large-diameter section that allows the rod to go into it about another 3/4" or so when the throttle linkage goes to full travel. If the rod is sticking out further, you'll need to drop the pan and see what's going on inside. It's a very simple setup- - - -the ONLY thing the cable does on a 350 is initiate the full-throttle downshift. The modulator controls the shift points. Jerry
| | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | Thanks Jerry. For some reason I wasn't notified of your reply.
I finally got it in with the top hat seal intact. | | |
