1 members (Alex52),
136
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | so i found a 3 speed that looks like the torque tube type but its got a open drive line end on it? its shorter then my 318 and 319s looks like the same lenght as a torque tube 3 speed? is it a pre55 converted to open? http://i1095.photobucket.com/albums/i465/bigdrewvigil/photoSHSHS.jpg
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | It is hard to view anything but an outline in that photo.
Are there any casting codes? Post them and their locations. Maybe someone can ID the transmission from a code.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Drew_Vigil, that is a terrible picture, but if the trans has a boss cast across the tail housing to accept a mount, then I would say it is a Chevy car transmission from 1958 through 1964, hope that helps.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's what the outline looks like to me to Bobb. But as the boys said Drew, check the casing numbers, that's the only way to really tell what'ca got there.
DG
Denny G Sandwich, IL
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Both cars & trucks used that transmission. It is a SM318 with the short tail housing. As 3B stated 59-64 car also 63-67 truck. The truck didn't use the rear mount. Some had the casting but were not drilled out. Very common transmission. Fred
