5 members (BC59, JoergK., Otto Skorzeny, Cosmo, 1 invisible), 60 guests, and 5 robots.
Topics128,181
Posts1,057,172
Members48,465
so i found a 3 speed that looks like the torque tube type but its got a open drive line end on it? its shorter then my 318 and 319s looks like the same lenght as a torque tube 3 speed? is it a pre55 converted to open?
http://i1095.photobucket.com/albums/i465/bigdrewvigil/photoSHSHS.jpg
It is hard to view anything but an outline in that photo.
Are there any casting codes? Post them and their locations. Maybe someone can ID the transmission from a code.
3B Online: Content
3 Online: Content
Hy Drew_Vigil, that is a terrible picture, but if the trans has a boss cast across the tail housing to accept a mount, then I would say it is a Chevy car transmission from 1958 through 1964, hope that helps.
That's what the outline looks like to me to Bobb. But as the boys said Drew, check the casing numbers, that's the only way to really tell what'ca got there.
DG
Denny G
Sandwich, IL
Both cars & trucks used that transmission. It is a SM318 with the short tail housing. As 3B stated 59-64 car also 63-67 truck. The truck didn't use the rear mount. Some had the casting but were not drilled out. Very common transmission.
Fred
