2 members (1955 1 Series, 1 invisible),
131
Mod | | | Forums66 Topics128,181 Posts1,057,192 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 10 New Guy | | New Guy Joined: Sep 2010 Posts: 10 | Which one should I rebuild and use on my 235 in my '53 3100? Standard rebuild nothing fancy, no performance mods on the engine
Thanks Robb | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Carter. Its a no brainer. You will enjoy good performance without leaks.
I have two on my engine.....
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2010 Posts: 10 New Guy | | New Guy Joined: Sep 2010 Posts: 10 | Great! thanks for the help | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I replaced the Rochester on my '53 Powerglide engine with a Carter YF 2100S. My gas mileage went from 14-15 to 19-20. And the acceleration and power are better. I was fortunate to find an unmolested and never rebuilt unit, and although it was rusty and stuck, with patience and the right rebuild kit from The Carb King, It runs perfectly. Can't say enough about it.
Kurt | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | With a proper rebuild and a carb kit from Carb King, my Rochester B does not leak and gives me 17 to 20 mpg depending on driving conditions | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Bolter2,
Glad to hear that you were able to get the Rochester to perform for you. I probably have had 3 or 4 different Rochesters on my 235 over the last 40 years or so, never could get better than 15 mph and they all leaked. I really thought 15 mph was the best one of these trucks could do until I put the Carter on. It's nice to know a good Rochester will do the same.
Kurt | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have always preferred Rochesters. Most of the time when they get bad gas mileage it is because the wrong base gasket was used or the power valve was assembled incorrectly.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Dave,
I guess you are right. After I put the Carter on, I decided to rebuild the Rochester, just for fun. I found that the power valve was installed incorrectly, (ball and spring in the wrong place) and the end of the power valve was split. No doubt this contributed to the bad gas mileage. This carb was a rebuilt unit I got at the FLAPS some years ago. It was also leaky.
The Carter is working so well for me that I haven't bothered to try the Rochester again. It just sits on the shelf.....
Kurt | | | | | Joined: Sep 2010 Posts: 10 New Guy | | New Guy Joined: Sep 2010 Posts: 10 | Anyone got info on the Carb King? I searched it and came up with this site but not sure it is the right one... Please advise,, THanks http://www.thecarburetorshop.com/Truckkits.htm | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Doc,
That's the right place.
Kurt | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | One thing I have found with Rochester's is when the float level is set correctly the fuel level is at the cover gasket level. I do not know if the gaskets that come in the rebuild kits wick gas more than the original gaskets but they seem to. What I do on all the ones I work on is to set the float level about 1/16" lower than called for, this seems to help with the leaking problem.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 10 New Guy | | New Guy Joined: Sep 2010 Posts: 10 | ok thanks for all the help guys, I intend on rebuilding the Carter and see how that goes...
Robb | | |
