3 members (Nick in Manitou, Hanks custodian, JW51), 106 guests, and 2 robots.
Topics128,062
Posts1,055,854
Members48,428
#898210 11/21/2012 6:55 AM
First off - Happy Thanksgiving to all you Bolt'ers
I am going to be purchasing a new wiring harness for my project. I will have to also get an Alt or Gen. I am going to convert to 12v.
So what is better to go with a Generator or Alternator?
And how can I tell what pulley I should go with 7/16 or 3/8
this is a 48 chevy 216 engine in a 53 3100 SB
gotta go hunt my turkey now
So I need the brackets and all - I am thinking that I should go with a 6 inch 12 V Generator - just not sure what size pulley
Alternator is good if you plan to use heavy load additions like ac, stereo, etc. Otherwise stick with a generator. I used one from a "55 Chevy before switching to an alternator. I had to fab upper bracket and purchased a pre made alt bracket in that swap.
Check the tech Tips pages for electrical info.
Drew
but does the pulley size matter
the pulley groove width needs to match the pulleys on the water pump and balancer - an alternator usually has a smaller diameter pulley than a generator
Riding in the Passing Lane
If you are going to do any amount of driving with it go to the alt. The output at idle, the dependability & added power are well worth it.
1972 Chevy c10 Cheyenne Super
If you're not worried about having the original look, go with the alternator. For the reasons George(wrenchbender Ret.) mentioned above.
Brian
1955.2 3100 Truck
Well and seeing I have no Bracket for either - the Alternator is much, much cheaper.
Bracket and Alternator = 100 bucks
Bracket and Generator = 250...or more
Then the harness
Think I will go the alternator route
Use an alternator. Go to your recycle yard and get a 80's delco alt. Make a bracket. Change your pully if it's not the one you need.You should be able to find a wide pulley on the net. I have seen them. The alt has one lead off the back wire it to the postitive on your battery. The alt will have a plastic 2 prong 2 wire that plugs in the top. You can get the 2 prong at auto parts store. The red wire you need to wire to the hot side of your coil. When you turn your key on it will turn the alt. on also. I have seen a (how to) on this site somwhere.good luck
Long story short - yes - alternator or generator RPM are proportional to output voltage. SO below say 1500 RPM (1,000 for sure)you will not get full voltage no matter what regulator does.
Dan Bentler
Here's the correct pulley for the wide belt:
http://www.speedwaymotors.com/GM-Alternator-5-8-Inch-Wide-Belt-Pulley-Plain,1868.html
Do a copy/paste into your browser- - - -the link doesn't work for some reason. It's also available in chrome or aluminum, same page. This reference is for a steel pulley.
Jerry,that's where I purchased the exact same pulley. pulley
It comes in chrome and aluminum finish as well.
Tim
1951 3100 Chevrolet
