7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible), 88 guests, and 1 robot.
Topics128,074
Posts1,055,910
Members48,429
#893316 10/30/2012 4:54 PM
Advice needed for the best way to remove an original 4-speed transmission from a 1952 1/2 ton Chevy pickup with torque tube. Needs synchronizers.
Best way is on a rack with a transmission jack. If you don't have that you can use a shop crane through the passenger door to lower it to the ground.
Thank you, cletis. Hope you have a Happy Thanksgiving.
FYI, the SM-420 weighs 135 lbs.
I've used jack stands and a floor jack for years cletis. I'd bet you've done it as well.
When I was a pup, I used to just wrestle that SM-420 in and out by myself.
Last time I did it I used a small floor jack. Didn't need to put the truck on any kind of stand. You will want to have a helper to keep the tranny stable as you work the jack.
Don't forget to drain the oil out of the tranny before you do this if you want to keep everything pristine in your shop. Oil can leak out of the shift tower when you lay the tranny on its side or it can leak out the back if you tip it that way.
Kurt
Thank you, for all advice.
Transmission came out fine. It's at the transmission shop for repairs.
Sorry to get in on your post but I have a 1953 GMC w/4 speed and I can only see 2 top bolts holding transmission in. Is there 2 lower ones or does the bellhousing have to come out to remove the transmission. Thanks
The lower bolts are inside the bellhousing and go into the transmission.
I have never done this job, one of tech tips is to put a t5 in and mount to bellhousing and being able to retain stock clutch and starter button with no other mods. is there any way those bottom bolts can be accessed except by bellhousing removal? If I read the other posts the engine would have to come out to be able to remove the bellhousing? This my son, who is 21, and would like to be able to stay at highway speeds. Any other suggestions?
To get at the bolts all you have to do is remove the tin cover on the bottom of the bellhousing and then you can get inside to remove the bottom transmission bolts.
Just totally retired. Have a 51 3/4 ton, just got moved in.
:dang: thanks for the info. Have a 51 doing the same thing.
