Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (TexasJim50, rick46ia, cmayna, Southerntruck, SNOYL, ShopRag, Mike Roache), 45 guests, and 1 robot.
Topics128,006
Posts1,055,271
Members48,418
How do you disassemble an Electrolock assembly?
I'm dismantling a '38 truck and I need to remove the coil from the end of the armored cable that runs to the ignition switch.
This is the first one I've ever seen that's still intact. Seems like most of them were hacksawed off years ago.
Any help appreciated.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
Give this page a try. It's an Acrobat file.
http://clubs.hemmings.com/wokr/library/Electrolock.pdf
Fred
52 3600
69 C-10
FredT,
Thanks for the link. Looks like I need to make a tool.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
Blue, think you answered your own question....
Got a Hacksaw?? :p What the HEY is this part you're talkin' about? Sounds like a "better" idea, left for someone else to fix!
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
GL,
Here is the coil end of the Electrolock:
Coil End
Back of the ignition switch:
Back of Ignition Switch
And finally the front of the ignition switch:
Front of Ignition Switch
The coil is listed separate from the ignition switch in the parts book so I assume that they come apart somehow. Any help appreciated.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
