0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89824 07/20/2002 7:37 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | How do you disassemble an Electrolock assembly?
I'm dismantling a '38 truck and I need to remove the coil from the end of the armored cable that runs to the ignition switch.
This is the first one I've ever seen that's still intact. Seems like most of them were hacksawed off years ago.
Any help appreciated.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#89825 07/21/2002 4:49 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 |
Fred 52 3600 69 C-10
#89826 07/21/2002 7:39 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | FredT,
Thanks for the link. Looks like I need to make a tool.
#89827 07/22/2002 5:11 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Blue, think you answered your own question.... Got a Hacksaw?? :p What the HEY is this part you're talkin' about? Sounds like a "better" idea, left for someone else to fix!
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#89828 07/23/2002 12:57 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | GL, Here is the coil end of the Electrolock: Coil End Back of the ignition switch: Back of Ignition Switch And finally the front of the ignition switch: Front of Ignition Switch The coil is listed separate from the ignition switch in the parts book so I assume that they come apart somehow. Any help appreciated.
