Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (baldeagle, thekid1950, cmayna, tclederman, Oswald, carbking), 54 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#898042 11/20/2012 3:58 PM
I have a built 348/3x2 that needs a home, I continue to think about trying to fit it in my 46 COE. The problem I keep coming back to is the vacuum or lack of. I need vacuum to run my hydro boost, wipers, dist. The 3x2 intake doesn't have a vacuum port, there is just one port off the center carb base that would go to my distributor. I could convert to electric wipers so that would leave me with the hydroboost. I guess I could tap one into the intake runner but not sure if that would work. In addition the cam is a 425hp 409 cam spec with 108 deg lube seperation so my engine vacuum will be minimal. Has anyone ever ran a booster solely off a vacuum pump?
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
Jrpontiac #898047 11/20/2012 4:17 PM
Hydroboosters don't use vacuum they use power steering fluid; vacuum isn't an issue.
One of these right?
http://www.cj3apage.com/Hydroboost.JPG
http://www.vancopbs.com/category_s/66.htm
http://www.hydratechbraking.com/
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Jrpontiac #898057 11/20/2012 5:06 PM
Jason; If you want vacuum for your wipers, get a fuel pump with vacuum. My fuel pump is off a 1954 Corvette...
Darrell, W.L.
1939 Chevy COE tow truck/My Stubbed toe
1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation.
I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
Grigg #898064 11/20/2012 5:24 PM
Beat me to it....
Hydro (hydraulics) boost...
One of these right?
Grigg
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Jrpontiac #898071 11/20/2012 5:59 PM
Perhaps Hydro-vac brake boost is what he intended.
Lots of electric & belt drive vacuum pump to be had.
BC
1960 C60 pasture art
BC59 #898157 11/20/2012 10:43 PM
Yes, I meant hydrovac. Has anyone ran a hydrovac or booster solely off a vacuum pump.
Jason
1946 GMC COE
Jrpontiac #898202 11/21/2012 6:21 AM
An electric one suitable is expensive, belt drive is cheaper.
Swap to a hydrobooster if you have PS, that's the best option I think.
Grigg
---All pictures---
Jrpontiac #898203 11/21/2012 6:25 AM
my 51 gmc 720 series rescue truck did. it was converted to a 8.2 detroit (fuel pincher). on the back side of the alternator was the vac pump. it ran the wipers and the humungous hyravac.
Jrpontiac #898227 11/21/2012 8:50 AM
My Hydrabost unit is also very compact. It only sticks out about 4"or 5" from the firewall. That helps a lot on a COE.
Darrell, W.L.
Jrpontiac #898263 11/21/2012 10:20 AM
3B Offline
Hy Jrpontiac, a couple of months ago a friend called me to diagnose a horrible noise on his newly installed tripower on a Buick Nailhead. I went over and found the engine had a huge vacuum leak, because someone had left the 1/4" pipe plug out of the base of the center carb. This carb is your standard Rochestor 2 barrel carb, if your tripower is using Rochestor carbs, you should have the same vacuum port available for you to use for your vacuum activated accessories, hope that helps.
