| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 27 New Guy | | New Guy Joined: Oct 2012 Posts: 27 | I'm trying to to put a one wire alt on a 39 216 can I use the pulley from the gen on the alt?and what kind of brackets will work? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Weld a lot, yes you should be able to use the generator pulley on the alternator, they are both 17 mm if I remember correctly. As to the brackets, you should be able to use the generator upper brace, but the lower one you will have to fabricate, or possibly purchase from one of the suppliers, hope that helps. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Just input. Check the Tech Tips on electrical issues. Randy Rundle of http://www.fifthaveinternetgarage.com/ offers lots of info along with other Stovebolters.
Drew
