1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#898175 11/20/2012 11:23 PM
I'm trying to to put a one wire alt on a 39 216 can I use the pulley from the gen on the alt?and what kind of brackets will work?
Weld a lot #898184 11/21/2012 12:24 AM
3B Offline
Hy Weld a lot, yes you should be able to use the generator pulley on the alternator, they are both 17 mm if I remember correctly. As to the brackets, you should be able to use the generator upper brace, but the lower one you will have to fabricate, or possibly purchase from one of the suppliers, hope that helps.
Weld a lot #898232 11/21/2012 9:01 AM
Just input. Check the Tech Tips on electrical issues. Randy Rundle of http://www.fifthaveinternetgarage.com/ offers lots of info along with other Stovebolters.
Drew
