7 members (Hotrod Lincoln, 1955 1 Series, TexasA&M48Truck, CandoBrent, Forty9, TUTS 59, MikeStone1953),
140
Mod | | | Forums66 Topics128,106 Posts1,056,211 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89811 09/10/2003 9:18 PM | Joined: Sep 2003 Posts: 6 Junior Member | | Junior Member Joined: Sep 2003 Posts: 6 | Anyone know where I can get a simple wiring diagram for ,, HEI dist. 2 wire alternator,starter,and ignition, I have a real mess here,and would like to clear it up.Its a 327 in a 62 chev shortbox.any help would be appreciated
Bob G. | | |
#89812 09/16/2003 6:17 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | Hi Bob: Yours is obviously not a stock set-up seeing how you are using an HEI distributor. HEI...the underside of the distributor cap socket should show wiring destination. One is straight to your ignition source (don't use a dropping resistor), the other is for a tach connection. 2-wire alternator...screw terminal to battery B+, other wire to idiot light (I think). I have a three-wire and the other wire goes to B+ also. Starter...solenoid to ignition switch via a neutral/park switch. Your solenoid may have an "ign" connection that was intended to be used for a points type distributor; it fed 12v directly to the distributor during cranking. You don't need this connection for your HEI. Ignition...your ignition switch should be getting power directly from B+, a 30A fuse in-line is a good idea so you don't start a fire when you have a short. Hope this helps. BTW, what part of Ontario are you from? I have lived in London, Sarnia, and a small town near Barrie. | | |
#89813 09/17/2003 5:16 PM | Joined: Sep 2003 Posts: 6 Junior Member | | Junior Member Joined: Sep 2003 Posts: 6 | Thanks for the info partner, I have it now.
I live in Fonthill, not far from St. Catharines
Bob G. | | |
