0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89765 12/18/2004 9:01 PM | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | You've either got a bracket for an old V-8, like a 283, or the alternator isn't designed to work with that bracket. I'll bet one of the older external-regulated alternators has a different spacing, or you've got the wrong bracket. Either way, you're going to need to modify something. It's easy to make a bracket, though. I do it all the time on racing engines where no standard brackets are available for the setup I want. Jerry
#89766 12/18/2004 9:10 PM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I wonder if purchasing an Alternator with the double groove pulley would be the easiest solution line up the belt?
Joe
Joe
#89767 12/18/2004 11:01 PM | Joined: Dec 2004 Posts: 27 Junior Member | | Junior Member Joined: Dec 2004 Posts: 27 | Good idea Chevy1. I'll try just replacing the pulley.
'63 Chevy c60 dump
#89768 12/19/2004 12:35 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 292 uses a different bracket. It is cast iron.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#89769 12/19/2004 1:40 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might try installing the alt. outside of the first hole or opposite of what you have and see if it will align up..seems like I had installed mine incorrect at first and it looked like that,, just a thought,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#89770 12/19/2004 4:42 PM | Joined: Aug 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 51 | I have the same bracket, but the pulley has a built-in 3/8" spacer on the back side next to the cooling fan. will try to Email you a photo.My 2 cents
1965 C-10 Stepside
#89771 12/19/2004 8:27 PM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | I had the exact same issue a few weeks ago. That's the right bracket but the wrong pulley. I had to remove the pulley off the old alternator and then all was fine. I have no idea what application that pulley is for but it sure doesn't work with 60's 292's!. alternator pulley As you can see, it's not that I have to use the outer pulley, it's that the inner pulley has a 3/4" space before the groove starts. What happened to your old pulley? -David Kustoms-and-Sleds | | |
#89772 12/19/2004 11:50 PM | Joined: Dec 2004 Posts: 27 Junior Member | | Junior Member Joined: Dec 2004 Posts: 27 | I just purchased the truck and this is how it was when I bought it. I will start looking for a pulley.
Thanks for the information.
'63 Chevy c60 dump
