9 members (VicZ, Ridgeback, RAC1812, Shaffer's1950, Gdads51, artinva, klhansen, Otto Skorzeny, 1 invisible), 122 guests, and 1 robot.
Topics128,077
Posts1,055,928
Members48,430
#89764 12/18/2004 7:27 PM
Junior Member
Junior Member
The alternator doesn't line up with the water pump on my 63 292.
The bottom braket looks like this
[img]http://www.partsamerica.com/product_images/AAP/MRG/6380.jpg[/img]
and looks stock but the alternator belt alignment looks like this
[img]http://img.villagephotos.com/p/2004-10/846536/Engine%202.JPG[/img]
What gives?
Thanks for any help.
'63 Chevy c60 dump
You've either got a bracket for an old V-8, like a 283, or the alternator isn't designed to work with that bracket. I'll bet one of the older external-regulated alternators has a different spacing, or you've got the wrong bracket. Either way, you're going to need to modify something. It's easy to make a bracket, though. I do it all the time on racing engines where no standard brackets are available for the setup I want.
I wonder if purchasing an Alternator with the double groove pulley would be the easiest solution line up the belt?
Joe
Joe
#89767 12/18/2004 11:01 PM
Junior Member
Junior Member
Good idea Chevy1. I'll try just replacing the pulley.
'63 Chevy c60 dump
#89768 12/19/2004 12:35 AM
Riding in the Passing Lane
The 292 uses a different bracket. It is cast iron.
smile
1972 Chevy c10 Cheyenne Super
you might try installing the alt. outside of the first hole or opposite of what you have and see if it will align up..seems like I had installed mine incorrect at first and it looked like that,, just a thought,,,Fred
Redryder pix
My Hotrod
I have the same bracket, but the pulley has a built-in 3/8" spacer on the back side next to the cooling fan. will try to Email you a photo.My 2 cents smile
1965 C-10 Stepside
I had the exact same issue a few weeks ago. That's the right bracket but the wrong pulley. I had to remove the pulley off the old alternator and then all was fine. I have no idea what application that pulley is for but it sure doesn't work with 60's 292's!. alternator pulley
As you can see, it's not that I have to use the outer pulley, it's that the inner pulley has a 3/4" space before the groove starts.
What happened to your old pulley?
-David
Kustoms-and-Sleds
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#89772 12/19/2004 11:50 PM
Junior Member
Junior Member
I just purchased the truck and this is how it was when I bought it. I will start looking for a pulley.
Thanks for the information.
'63 Chevy c60 dump
