1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#897394 11/17/2012 6:05 PM
I have a 1954 235. Iam having trouble finding the 54 as a replacement engine. Will the later engines work without any adaptations? I see a 1957 on Craigslist. My engine is bolted to a four speed in a 1946 truck.
Oldschooldude #897399 11/17/2012 6:43 PM
If you use all of your components including the bell housing I don;t see you having any problems installing a later 235 engine as long as it has the timing cover mount.
Oldschooldude #897400 11/17/2012 7:01 PM
You will need to do something about the water pump. The most popular solution is the water pump adapter plate.
1951 1 Ton Completed
truckernix #897620 11/18/2012 4:27 PM
Is it that the pulley does not line up?
Oldschooldude #897626 11/18/2012 4:44 PM
The fan won't be centered behind the radiator
Oldschooldude #897716 11/18/2012 9:38 PM
The fan will be in the radiator unless you shorten the shaft and put a different pulley on it. Not being centered won't be a problem with a good cooling system. I have driven many miles with a later 235 with a shortened pump shaft and a 292 Ford pulley in a '55 first.
