0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 11 New Guy | | New Guy Joined: Nov 2012 Posts: 11 | I have a 1954 235. Iam having trouble finding the 54 as a replacement engine. Will the later engines work without any adaptations? I see a 1957 on Craigslist. My engine is bolted to a four speed in a 1946 truck. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | If you use all of your components including the bell housing I don;t see you having any problems installing a later 235 engine as long as it has the timing cover mount. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You will need to do something about the water pump. The most popular solution is the water pump adapter plate. | | | | | Joined: Nov 2012 Posts: 11 New Guy | | New Guy Joined: Nov 2012 Posts: 11 | Is it that the pulley does not line up? | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | The fan won't be centered behind the radiator | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The fan will be in the radiator unless you shorten the shaft and put a different pulley on it. Not being centered won't be a problem with a good cooling system. I have driven many miles with a later 235 with a shortened pump shaft and a 292 Ford pulley in a '55 first. | | |
