Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Wally / Montana, Tyler Watts, 2 invisible), 139 guests, and 3 robots.
Topics128,281
Posts1,058,464
Members48,490
#89757 03/17/2002 8:40 AM
I am rewiring my 53 half ton and ran into a problem on the light switch. Someone rewired it at some time and upgraded to 12 volt etc. The light switch has seven wires, the headlight power wire is a double wire, but I only have one power wire coming from the fuse panel. Do I splice the one wire into the 2 wires coming from the switch. Seems logical but I am not sure, can anyone help on this? Thanks, Coach Frank
#89758 03/17/2002 7:38 PM
You got me baffled on that question. There are two wires that go to the headlights alright but they run from the dimmer switch on the floor. One wire from the light switch on the dash goes to the dimmer switch. Did this help at all? Someone sent this while back it also may help
