| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | ok I've got spark to the starter, when I turn the key on i've got lights, gauges ect. but no fire to the coil????? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year truck? What engine (size/year)? What kind of starter (foot actuated or electrical solenoid actuated)? Describe the routing of your ignition wiring to the coil.
| | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | 42 chevy 1/2 ton original 216 with foot starter the wiring is the original 70 year old harness complete with flexable shielded conduit from ignition switch to coil. I've read these trucks are negative ground VS what was considered the norm (positive ground) in the day. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | VS? 6v USA Chevrolet electrical systems in trucks were standard through 1955-1st. In 1942, I think you might have had some sort of Reversing Switch mounted on the starter assembly? Someone else will have to offer diagnostic advice regarding the electrical components of this type of system. | | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | You are correct ,I found an old wiring diagram and the polairity reversing switch is located betwen the coil and the distributor
thanks | | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | Wow...thanks for the link to the shop manual...much appreciated | | |
