6 members (diseasel, Otto Skorzeny, Wayne67vert, klhansen, MickeyP, Jims46), 109 guests, and 1 robot.
Topics128,034
Posts1,055,552
#897379 11/17/2012 4:43 PM
ok I've got spark to the starter, when I turn the key on i've got lights, gauges ect. but no fire to the coil?????
Mr Crosswrench #897510 11/18/2012 8:56 AM
What year truck?
What engine (size/year)?
What kind of starter (foot actuated or electrical solenoid actuated)?
Describe the routing of your ignition wiring to the coil.
tclederman #897537 11/18/2012 10:43 AM
42 chevy 1/2 ton original 216 with foot starter
the wiring is the original 70 year old harness complete with flexable shielded conduit from ignition switch to coil.
I've read these trucks are negative ground VS what was considered the norm (positive ground) in the day.
Mr Crosswrench #897541 11/18/2012 10:57 AM
VS?
6v USA Chevrolet electrical systems in trucks were standard through 1955-1st.
In 1942, I think you might have had some sort of Reversing Switch mounted on the starter assembly? Someone else will have to offer diagnostic advice regarding the electrical components of this type of system.
tclederman #897548 11/18/2012 11:25 AM
You are correct ,I found an old wiring diagram and the polairity reversing switch is located betwen the coil and the distributor
thanks
Mr Crosswrench #897551 11/18/2012 11:30 AM
Wow...thanks for the link to the shop manual...much appreciated
