3 members (klhansen, dt235sd, 1 invisible), 67 guests, and 0 robots.
Topics128,049
Posts1,055,679
#897007 11/15/2012 11:13 PM
Anyone have suggestions for a good rubber floor mat for my 1965 high hump 4-speed?
Thanks in advance.
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
Here Ya Go! Mark's a buddy of mine, if he says its good you can count on it. thumbs_up
http://67-72chevytrucks.com/vboard/showthread.php?t=529854
http://www.stockinteriors.com/
I was looking through my catalogs the other night for something else, and I believe it was the Truck Shop in Orange CA, that lists carpet and a rubber mat. I'm going off the top of my head, so I will need to check further. I have not used one, just saw it listed.
i got the heavy duty one from lmc for my high hump 3/4 ton 64 wrecker and it had held up really well. i bought the standard black mat for the 63 i have and it is ok.
I was wrong on my response earlier, truck and car shop does not show one for the high hump 64 - 66, only low hump and earlier years.
Thanks for the responses guys. Does anyone know if the '60-'63 floor mats are the same as the '64-'65? SD66Burb, that's what I was discovering. I will check out the one John mentioned.
I see a HUGE difference in price between LMC and Classic Parts but these are for the '60-'63 trucks. I'll give them a call and see what they say.
I just got my cab back and I am excited to get back to work on this truck. I've got no excuses now, it's all on me to put it back together.
Tom
Nesto426 #897317 11/17/2012 10:13 AM
Both of the companies I mentioned discontinued the '64-'66 floor mats. One of them said the only difference between the two year types is the 60-63 clutch hole is a 1/2" off. I still wonder about the $90 difference though. LMC doesn't have a rubber one anymore.
I'm not sure I like the look of the polyvinyl ones I'm trying to shoot for original look.
Tom
Check with Tony at 4-5-6 Chevy if their is anyone out there that would have a quality part it would be him.
You Learn more Listening than Talking
Nesto426 #897462 11/17/2012 11:30 PM
I'm also looking for a floormat that is similar to the original. High Hump. 4-speed. Not full coverage - just the front part of the cab as the original mat.
I think I will try the 60-63 high hump from Classic Parts. I'll let you know how that works Lost. By the way if you type stovebolt in for discount code you get 10% off.
Tom
Well, I went ahead and ordered the 60-63 high hump from Classic Parts. I like it. It fits the 65 pretty well. It does not have the hole for the 4-speed but I can cut that out. I added pictures to the end of my photobucket. I do not have the jute under it I just wanted to see how well it fit. The rubber is real rubber and very flexible.
Tom
I would at least call "stock interiors.com". They really treated me right. They made a long pickup rubber mat extra long so I could fit it in a panel truck. Reasonable prices and they have mats and carpets for everything. Just my $.02.
best wishes,
Les
I've bought 7 sets of carpets from stock interiors. Have they all been correct first try - no. But they made a huge effort to get them right and I am very satisfied with them and in the end all were right. Couldn't ask for a nicer bunch of people to work with, even when it's not their fault they go out of their way to help and make it right. I won't go anywhere else.
john
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
