1 members (Bucker), 144 guests, and 2 robots.
Topics128,196
Posts1,057,391
Members48,471
Well i moved my truck to my buddy"s newly acquired farm last Sunday... I should have more of an opportunity to work on it there and its in nice dry garage.
we used a dolly to pull it the 4 miles or so which went off without a hitch. we used a come--long to pull it on the dolly seeing as it hasn't ran in about 20 years.
earlier this year i did an oil change but have barely touched it otherwise since i got it about 6 months ago..
well we figured it would be easier to get it running than to push it around with the skidsteer so we figured we'd tinker a bit.
turned it over a few times with no plugs, replaced 1 broken plug, fixed a wire connection in the igniion system, cleaned up the points...
we bypassed the gas tank in favor of an old gas can on the passenger floor. and rigged up a battery sitting on the fender since the tray has rusted away...
all told about an hour later we hit the start button and with a little throttle play she roared to life! so i got to drive my truck (sans brakes) for the first time off of a dolly and into a garage smile
it actually runs really smooth and sounds great! oil pressure is about 15-20 psi at idle ( oh yea, so far all gages work) so that is good. started dropping toward 10 but engine was getting hot so we pulled it into garage and shut it down. I'm thinking t-stat is stuck closed.
I'M SO PSYCHED
Feels good, don't it.
Congrats!!
It does feel good.
Professional Novice
gonna start tackling brakes tomorrow....
now that it goes i guess i should make it so it will stop...
Tj
Good idea.
Congratulations
well it looks like the master cylinder is shot..
and the cab is way worse than i thought
i was hoping to get it running as is and drive it on farm plates for a bit but idk if that is going to make sense...
time to find a cab!
