| | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 76 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 76 | I have an exhaust leak. I did find that the bolts holding the exhaust pipe to the exhaust manifold were loose and corrected that. I also noted that at the back (firewall) of the exhaust manifold a bolt was missing to hold the back "ear" of the manifold. There should be one there right? I currently have six bolts in the manifold. Thanks - Tim-o | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The rear manifold bolt from the factory was a stud. Quite often it is replaced with a bolt. Might want to double check.
Hopefully the exhaust donut wasn't beaten up too bad from the bolts being loose.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | a lot of the heads i have seem the very first one and very last one are alignment studs with no threads on ends. they just sick out enough to aid in instillation of manifolds. they can usually, and it is recommended by several knowledgable folks, be removed with a pair of vice grips and regular ones with fine threads on the outter end can be installed. the problem i have had is if manifolds work loose then they warp with heating and cooling cycles. then it will take resurfacing the 2 together to get them to not leak. | | | | | Joined: Jul 2009 Posts: 76 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 76 | Thank you for your help. Now that I think of it - I have seen the "alignment" studs before. The front exhaust manifold hole is filled with a bolt. The rear, I can place a bolt in the hole in the exhaust manifold hole - bit there doesn't seem to be any threads there. Tomorrow - I'll get a mirror out and get a bright light and see what I have there. I did think about the exhaust pipe donut being burnt too. Finally I did think about the resurfacing. All good thoughts - I appreciate your time and efforts. Stay tuned... Tim-o | | | | | Joined: Jul 2009 Posts: 76 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 76 | I have determined that the exhaust leak is at the manifold. I have the non-integrated manifold. Are the gaskets different? Tim-o | | |
