| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | The new headliner came today from CP. The problem is how to install it. I have the rubber to go arould the roof edge. What holds the new panel in the center,glue,bows or what? Does there need to be some sort of mating under it to build it up to the lip where the rubber goes? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the repro plastic headliner? the originals had a jute backing and were glued up - the rubber takes up the gap to hold the edges, don't try to fill the gap with anything, the rubber is a tough enough install because of the way it needs to be worked onto the lip, if you decide to put any insulation behind the headliner, cut it shy of the edge
Bill | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | It is a thin plastic. With no support in the center I believe that it would sag down.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 3M spray contact cement is what I'd use
Bill | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | I will pickup some 3M today. To see how it goes on,I tried putting on the headliner rubber, and it is very tight and hard to slide on the lip. Any way to making it easy to go on? I was thinking of spraying it with WD40. | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | I have rubber lube for installing tires, so I would use that. WD 40 might work; will it damage rubber?
My reproduction headliner was rigid enough that the rubber part held in firmly in place with very little sag. I didn't glue it up.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | I put it up with clothes pins holding it around the edge as would the rubber and it saged in the middle. I then put some 1/8" self adhesive insulation/sound deadner to the roof. Then I used 3M adhesive to glue the headniner to it,letting it stay untill tommorow.I will then try putting the rubber in. I have rubber lube for installing tires, so I would use that. WD 40 might work; will it damage rubber?
My reproduction headliner was rigid enough that the rubber part held in firmly in place with very little sag. I didn't glue it up. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If you're looking for something to get the rubber in easier use soapy water. Don't use WD-40. It will stay greasy.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | A really hot work area or a nice hot day in the sun to make the rubber more plyable. | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | That rubber is a major PITA! I tried using dish soap but found that vaseline or petroleum jelly worked better. It also helps to do it on a hot day or somehow get the rubber warmed up real good. I put some thin aluminum foil wrapped insulation on top of the headliner and didn't glue any of it, hardly sags at all. Darren | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | Well the headliner and the rubber retainer is in. I put a self stick insulation that is used for HVAC ducts, got it from Home Depot. It is 12" wide, 1/8" thick and tin foil on one side. Easy to put up in two strips. I then spayed 3M contact to the insulation and the headliner and put it up. to keep the headliner in place untill the glue dried I used clothespins around the edge.I did not heat the rubber even though it was in a cold garage over night. To lube it I used vasaline on about 6" at a time, worked in the starting end and then used a ballpien hammer to hit it in, working it in a little at a time with the hammer. Worked out very good with no problems, took about one hour for the rubber. Thanks everyone for your help and input. | | | | | Joined: Dec 2012 Posts: 21 New Guy | | New Guy Joined: Dec 2012 Posts: 21 | I am having the same issue in my 1958 Apache. Does the rubber go in before the headliner? That was my plan. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No, put the headliner in first. It glues into place as red58 says. Use the 3M spray adhesive (Super 77 works best) to attach it. The rubber goes in after. Use rubber lube or Syl-Glyde to help the rubber paice go in.
Bill Burmeister | | | | | Joined: Dec 2012 Posts: 21 New Guy | | New Guy Joined: Dec 2012 Posts: 21 | | | | | | Joined: Dec 2011 Posts: 1 Moderated | | Moderated Joined: Dec 2011 Posts: 1 | Just put the headliner rubber in today. Used 3m glue yesterday on the headliner. Greased the rubber with Vaseline and tried using a brake adjusting tool to push the rubber in the grove. It worked but was very hard. About half way around I tried using a rubber mallet to tap the rubber into the grove. It worked great. Still had to use the Vaseline but the mallet was the trick! | | |
