0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#896980 11/15/2012 9:21 PM
Has anyone made a recent purchase of battery cables. I am getting close to starting my truck after a couple of years and want to replace my battery cables.
I found some in the "Truck Shop" (orange county) catalog but from the photo they don't look to be a very big gauge wire.
The positive cable in the LMC catalog has a crimp connector on the wire that comes off of it. After all this work I really don't want a crimp connection where it is visible.
Rusty64 #896985 11/15/2012 9:39 PM
Tractor Supply Company usually has heavy gauge battery cables.
If you have a 6v system, you should have 2 gauge or less. 00 (2/0) gauge is what I use.
Rusty64 #896989 11/15/2012 9:53 PM
i was actually at a auction and got a electrical crimp comector specificly for larger gage conectors a year or so back. it has large handles like bolt cutters. i cut back the insulation coating right up to the depth of the conector and slid it in and crimped it. it looks just like a factory cable and is very tight. i did the lug ends for my 6 volt system using heavy wire.
Rusty64 #897607 11/18/2012 3:23 PM
If you want the original GM, spring-clip, style battery cables, we use:
www.wiringharnesses.com
M&H Electric Fabricators, Inc.
