| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | Has anyone made a recent purchase of battery cables. I am getting close to starting my truck after a couple of years and want to replace my battery cables. I found some in the "Truck Shop" (orange county) catalog but from the photo they don't look to be a very big gauge wire. The positive cable in the LMC catalog has a crimp connector on the wire that comes off of it. After all this work I really don't want a crimp connection where it is visible. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tractor Supply Company usually has heavy gauge battery cables.
If you have a 6v system, you should have 2 gauge or less. 00 (2/0) gauge is what I use.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i was actually at a auction and got a electrical crimp comector specificly for larger gage conectors a year or so back. it has large handles like bolt cutters. i cut back the insulation coating right up to the depth of the conector and slid it in and crimped it. it looks just like a factory cable and is very tight. i did the lug ends for my 6 volt system using heavy wire. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | If you want the original GM, spring-clip, style battery cables, we use: www.wiringharnesses.comM&H Electric Fabricators, Inc. | | |
