1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Does anyone have any suggestions on how to complete the connections for the clutch/brake pedals/trans linkage on my 50 burb. To start with, I have a 50 GMC frame that I've altered the front cross-member to make a 56' 235 engine & bellhousing mount in the gmc frame. It has the stock rear engine cross member. I Am putting a 3 on the tree in it.What years of engine/trans and steering can be assembled together? Does it matter what year trans I use? Also my bellhousing doesn't have the shaft on drivers side of bellhousing for the shift linkage to mount on. Does that matter? Does that shaft press into the bellhousing?Any help will be greatly appreciated. Pics will be a big help. (HELP!!! the hole seems to be getting deeper)Dave
| | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | Dave. I'll give this a shot but let others jump in too. I believe that you're going to need a bell housing out of a 47-53 engine with a three on the tree shifter. You will have to find the appropriate steering column. That would be a gmc or chev three on the tree column from 47-53.
I'm not sure about the trans selection question but I would think that ny three speed from that era should work
Be cognizant on flywheel and starter selection. There is a 138 and 162 Tooth (if I recall) flywheel and starter combination. be sure the starter and flywheel match
Im not sure about your last question on the Shaft. Get somebody else to validate these answers. Good luck
| | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Paul; thanks for the feed back. First, I may have a 162 tooth(maybe 159 tooth?, not sure)flywheel. It was on the engine (56 truck) when I rebuilt the engine. That will probably explain why I can't use the stomp starter. The drive gear is different than the starter with the solinoid, not leting it engage with the flywheel. So I will either have to change the flywheel(UGH)or use the newer starter. Does the 138 tooth interchange with the 56 engine? I don't believe the drivegears can be switched. The linkage that connects to the 3 speed connects to a lever that mounts onto a shaft that is on the dr. side of clutchhousing. Is the shaft a press fit into the housing? I have the levers but not the shaft and the spring and hardware that holds the lever onto the shaft. Is the bellhousing different on the 56 than the 50? My bellhousing has a hole on the drivers side for a shaft. Whats thecasting no. for the 47-53 housing? Are you still looking for a heater? mine is still availible. Thanks again for the help, Paul. Dave
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That's a lot of questions.
The 3-speed shaft on the driver's side of the clutch housing is pressed in.
The geometry of the bottom of the truck clutch housing changed in 1954. The angles in the frame fross member changed.
The 216/235/261 flywheels can be mounted interchangeably. Use the clutch assembly that works on the flywheel you are using (including the throwout bearing). Use the starter that matches the year/teeth for the flywheel, 6v or 12v starter/flywheel combination.
Mechanical foot-operated starters were used up to 1959.
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Your flywheel will be a 162T. The 153 was found on 1960s BBCs.
Best wishes,
Les | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I want to say Chevrolet: 6volt is 139 tooth flywheel 12 volt 168 tooth flywheel
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, 139 teeth or 168 teeth, as Tim posted.
| | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Neil; Thanks for the pics of starter. I believe thats the same starter that I had rebuilt. If so, then I can use it with my 139 tooth flywheel, right? And my 4 speed will bolt up right? Is the clutch plate for the 139 tooth flywheel the same as the one I have in there now connected to the 168 tooth flywheel? I don't want to have to take this apart again, so I'm a little gun shy. Again, thanks for your help. Appreciate it MUCH!!! Dave
| | | | | Joined: Feb 2006 Posts: 64 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 64 | Clutch plates should be the same and should match up to the surface on the flywheel, there are at least 4 differant sizes of clutchs. I run the largest out of a two ton, I believe it is 11" its a a beast, but she dont slip.  barks 3rd gear if I want. Flywheel, clutch and pressure plates should act as a set. All should match, Clutch should match grind surface on flywheel, Pressure plate surface should match up to clutch and Bolt circle should match up to flywheel. Get your tape measure out and go through what you got and make sure it all matches. I keep all mine together as sets along with the starter that was with it when removing drivetrains. Neal, | | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | | | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Thanks to all who helped me with my Flywheel/starter/clutch/trans, problems. I was able to get it to come together today. HOORAY!!!! That's one less headache. Dave | | | | | Joined: Feb 2006 Posts: 64 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 64 | | | |
